warrior vibrating???
Old Jun 18, 2004 | 09:24 AM
Gwinnwarrior's Avatar
Default warrior vibrating???
when i shift into 4,5,6 gear and mash the gas it feels like its not putting power to the ground. it acts like something is slipping. could this be the tranny or what, it doesnt do it in 1,2,3. it will spin like heck and go in the first three gears, after that though it sux. what could it be? possibly bigger tires, i had 22 shredders on it, changed them when it started and put 22 spider trax on it, and it still does it...please help, its got me stumped here
Old Jun 18, 2004 | 09:34 AM
4wheelsc's Avatar
clutch or valves probably. Is it smoking?
Old Jun 18, 2004 | 09:36 AM
doesnt smoke at all. the valves do knock a little bit, but ive never had a quad that hasnt had them clack a little bit. why would the clutch do it only in those gears, do i need to tighten the clutch cable??
Old Jun 18, 2004 | 10:08 AM
4wheelsc's Avatar
yeah I would try to tighten your clutch and check your valve clearance if you need a manual pm me and I'll e-mail you a PDF manual
Old Jun 18, 2004 | 10:23 AM
thanks, ive got a manual tho. i will tighten that cable and see what happens there, thanks for the help.
Old Jun 18, 2004 | 10:32 AM
TRLYFZ450's Avatar
It is the clutch slipping. You will have to replace you friction plates. When that happened on my warrior i went with a barnet clutch kit. around 100 bucks. and it wasnt to hard to install.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
