400 2 stroke engine trouble
Old Jun 18, 2004 | 04:10 PM
ktk's Avatar
ktk
Default 400 2 stroke engine trouble
Hi guys, dad has a 94 400L that I have been working on. I pulled the cylinder and the piston skirt broke off and busted both cases. I have figured I could do the work but it will cost him more money in parts than he cares to spend on it. He never has liked the 2 stroke engine (not good at all for farm work) and has contemplated getting rid of it. I mentioned he might be able to swap in a 4 stroke engine such as the one from the 500 Scrambler but I didn't know for sure.
What I'm asking is that if I can pull the engine and swap it out for a 4 stroke if I can find one reasonably priced? I'm guessing here but upon a glance, the frame appears to be very similar to that of the Scrambler's of the mid 90's isn't it. Isn't the drivetrain pretty much the same on the Polaris models. I don't know as this is the only one that I've had any extensive experience with.
I'd appreciate any help you can offer to me.
Old Jun 18, 2004 | 06:27 PM
polarisman3's Avatar
you might also want to look at getting a 425L engine that was around in the '94 area that is if it would fit.....
Old Jun 18, 2004 | 07:04 PM
ftwflh's Avatar
Looks like it could be time to part the old 400L ott and buy another quad.[img]i/expressions/face-icon-small-sad.gif[/img]
Old Jun 18, 2004 | 10:11 PM
401's Avatar
401
The frames are the same with different mounting points for the engine.It can be done with not a whole lot of fabrication.Almost will bolt in.
Old Jun 18, 2004 | 10:17 PM
DGScrambler400's Avatar
an engine switch wouldn't be very hard
kelleycully
Sep 15, 2016 02:57 AM
SDR-II
Sep 29, 2015 01:06 AM
ltrmc02
Jul 22, 2015 04:50 AM
Ask the Editor
12
Jul 21, 2015 06:57 AM
Shifts
Jul 3, 2015 07:59 AM
