Front tire with cut
Old Jun 18, 2004 | 06:04 PM
campin's Avatar
Default Front tire with cut
I recently noticed a 3" cut in the rubber (between lugs) running across the width of the tire. This cut in not very deep and the tire is not losing air. Is the tire safe to use or should I replace it?
Old Jun 22, 2004 | 05:44 PM
Ball's Avatar
Tires often get these "slits" from everyday use over common terrain. If it holds air oven time and it is not too deep I would not worry about it. If we were talking about a vehicle used at high speeds with quite a bit of pressure in the tires, such as automobiles, that would be different. But with the relatively low speeds and low tire pressures of ATV's you are in no danger.
Reactant
Mar 30, 2022 02:08 AM
baysport
Jul 23, 2015 11:37 AM
rcappie4
Jul 18, 2015 07:51 AM
JackTheKing
Jul 14, 2015 09:09 PM
tporath
Jul 11, 2015 12:31 PM
