Flywheel removal....
Old Jun 19, 2004 | 07:01 PM
Troyer23J's Avatar
Default Flywheel removal....
I have a puller on there as tight as I can turn it,I have hit the bolt with a hammer, I have been spraying it every 15 or 20 minutes with WD-40, I have poured boiling water on it as i read not to use a torch, and it still wont budge....
I need to get it off so I can get it lightened, any other thoughts?
Old Jun 19, 2004 | 07:07 PM
thewayout420's Avatar
use a impact gun if its being that stuborn..
Old Jun 19, 2004 | 07:13 PM
EAB's Avatar
EAB
make sure the threads of the puller and any other friction contact point is well lubricated. I smoked an old puller trying to get mine off, so I bought a new puller, greased it up and used an impact gun. It made a pretty good pop when it came off.
Old Jun 19, 2004 | 09:45 PM
Troyer23J's Avatar
how do y'all keep the flywheel from spinning when trying to pull it?
I have a pry bar through on slot on the puller but its not working great...
Old Jun 19, 2004 | 09:54 PM
i dont think i had to hold it using the impact gun..
Old Jun 19, 2004 | 09:56 PM
BeltDrive's Avatar
As the others have said, use a impact gun and it will come right off. Make sure you are using the right puller and not a two jaw puller. If you use the impact you won't have to worry about it turning on you.
Old Jun 19, 2004 | 11:49 PM
Troyer23J's Avatar
Got it. Finally. Just needed another set of hands.
Made one heck of a pop, ya know the kind where you know it either came off, or something big broke, then there is the nervous half a second when you gotta find out which one it was.
well, it came off, so its all good.
thanks for the help again guys.
Old Jun 20, 2004 | 12:17 AM
modquad's Avatar
Before you put it back on, apply a very thin film of anti-sieze to the crank. That way, it will come off nicer the next time.
Old Jun 20, 2004 | 02:01 AM
braveops's Avatar
when i got mine off it was a pain i did the impact way and gave up end up holding the clutch and using a big rachet and like you said pop it was off i thought i might break something
chingchangchong
Aug 7, 2022 11:36 AM
Joe454
Nov 20, 2020 01:19 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
raman8tor
Sep 20, 2015 07:35 AM
