how to move needle jet??
Old Jun 22, 2004 | 04:15 PM
tbsleeper's Avatar
Default how to move needle jet??
how do u move it a space up????
Old Jun 22, 2004 | 04:18 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
by removing the needle and moving the e-clip one slot closer to the pointy end
Old Jun 22, 2004 | 04:21 PM
tbsleeper's Avatar
say whatt????? thing is do i have to remove the whole thing?? because i dont even know what slot its at now. and i can seem to remove the cable?? how do u do that?
Old Jun 22, 2004 | 04:22 PM
BUBASCRAMBLER's Avatar
The top of your carb where the cable goes in will screw off.
Pull your slide assembly out
The needle is held by into the slide with an E-clip
You can move that clip to different posisions on the needle to raise and/or lower the amount of needle that is in/out of the main jet.
Old Jun 22, 2004 | 04:26 PM
tbsleeper's Avatar
alright i got one part down. im just having trouble getting the cable off. do u push it down into the open part and it will release??
Old Jun 22, 2004 | 04:32 PM
http://www.partsland.com/index.cgi?N...250-CARBURETOR
Part 1 screws off.
2,3,4,5,6 will also come out
#3 holds the cable.
You adjust part #30(clip) on #4(needle) up or down in the slots on 4
Lowering the clip on the needle raises the needle
Raising the clip loweres the needle.
Old Jun 22, 2004 | 04:36 PM
tbsleeper's Avatar
alright i got it all apart and now how do u get the eclip off??
Old Jun 22, 2004 | 04:41 PM
You can use a small screw driver to pop it off, put a shop rag over top and bottom so you don't lose it.
It should pop off easy.
push on by hand
Old Jun 22, 2004 | 04:49 PM
tbsleeper's Avatar
so by moving the eclip up one notch it will lean out the midrange???
Old Jun 22, 2004 | 04:50 PM
tbsleeper's Avatar
o ya thanks bubbascrambler and bing!!!
Dewhound
Apr 20, 2017 02:25 PM
Dammar
Apr 20, 2016 06:03 AM
Ahtatu
Sep 28, 2015 12:14 PM
wrencher82
Sep 24, 2015 03:39 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
