ohm's or voltage from stator
Old Jun 23, 2004 | 01:09 PM
Lomax's Avatar
Default ohm's or voltage from stator
I am about to start "repairing" the wiring harness on my 86 250r. the guy i got it from said the stator was bad but as hacked up as all the wires are, I am hoping that they are the culprit. If they are not does anyone know how to test the stator to see if it is bad?? I have a test light and a multimeter. Also which wires do i hook it up too??
Old Jun 24, 2004 | 07:33 PM
Lomax's Avatar
Can noone help me on this one??
Old Jun 25, 2004 | 02:31 AM
ThrashAndCrash's Avatar
OHMS....but my book only covers the 200's so I can not tell you what wires to check.....as far as the specs ...if it ohms out, it is good, if I am reading this correct.
Old Jun 25, 2004 | 09:16 AM
hondawontdie's Avatar
Call your local service place and they will be able to give you the proper readings.
Old Jun 25, 2004 | 11:24 AM
Lomax's Avatar
I need to know what it is supposed to ohm out at though. My local service shop would not really be able to help me.
Old Jun 27, 2004 | 10:39 PM
whiteman350x's Avatar
Here you go.
exciter coil:blk/red and ground:50-250 ohms
lighting coil:white/yeoolw and ground:0.1-1.0 ohms
pulse generator:blue/yellow and green/white: 50-200 ohms
Hope this helps.
Whiteman
Old Jun 28, 2004 | 12:18 PM
Lomax's Avatar
Thanks man that ought to help me get it going again
ultangler
Nov 30, 2024 01:35 AM
Joe454
Nov 20, 2020 01:19 PM
Gwolf228
Feb 18, 2017 01:36 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
kbazzy
Sep 26, 2015 11:26 AM
