Xplorer 400 Chain tension?
After tightening the chain do you check the tension with the suspension collapsed? The owner's manual doesn't say one way or the other. I'm worried because the chain gets tighter with the suspension collapsed. Also, how much deflection should the chain have? Any help would be appreciated.
You can do it other ways but this is how you should do it.. ratcet strap your suspension down in the back till it is bottomed out and tighten the chain until there is 1/4 to 1/2 deflection.... I never really do it this way but I did the first couple times and it works.... otherwise just tighten it so its not hanging there or so it doesnt slip.......... Good luck
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
