250es carb problem
Old Jun 27, 2004 | 01:05 PM
kooroc's Avatar
Default 250es carb problem
the gas is pouring out of the carb drain on my 1987 atc250es big red. swapped the drain screws, but still pouring. never has done this before. maybe that the bowl cracked all of a sudden? it had a slow drip, but now pours.
update: i do not see any exterior cracks. if the float bowl is needing replacement, is it possible, or more trouble, to replace the bowl without removing the carb?
Old Jun 27, 2004 | 04:06 PM
ThrashAndCrash's Avatar
if it is just the drain screw, before you buy a new bowl use some JB weld to seal it up. you will just have to take the bowl off to drain it every once in awhile. quite a bit easier and cheaper for the time being. Then you can always get a new bowl down the road.
Old Jun 27, 2004 | 07:08 PM
kooroc's Avatar
bowl is off and checked. it holds gas no problem, drain screw seals.
looks like the float was hung and it filled until it overflowed.
float is only 2 years old, so i doubt it has a hole. mabe trash was causing it.
so far, cheaper than a $72 bowl.
Wooodyii2
Nov 16, 2020 07:14 PM
Ty Speece
Jul 2, 2015 04:59 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
