YFZ air box lid removal??
Old Jun 30, 2004 | 12:04 AM
Dingo2's Avatar
Default YFZ air box lid removal??
Help me with some jetting on the YFZ---K&N with lid off...thats it for now-no S/A removal suggestions..cam mod suggestions, just a K&N with lid off at 1000 feet above sea level.
Stock main is what size? and should be jetted to what?
Pilot--same question?
Needle clip position..same question..
My buddy has a stock YFZ and he's gonna do the cam mod and pipe down the rode and is just wanting some jetting recomendations with lid off/K&N...
Thanks
Old Jun 30, 2004 | 12:25 AM
hondarider300's Avatar
with just a lid remove and filter, and no exhaust ur probobly gonna go up maybe 1 size on the main, and i wouldn't even touch the rest. maybe a 1/8th turn richer on the screw.
Old Jun 30, 2004 | 09:20 AM
Dingo2's Avatar
Anyone else???
Old Jun 30, 2004 | 11:24 AM
Flynbryan's Avatar
If you change your air intake/flow that much your going to want to richen your pilot jet circuit. My buddy had a yfz and even from just pulling the pea shooter out(Spark arrestor) he needed to raise the pilot jet. Just read your conditions. If it farts and pops after you do the modifications, then you'll have to adjust the jetting. Jetting is trail and error and you'll never get it "right" with recommendations. You'll only get it "close"......
Old Jun 30, 2004 | 02:50 PM
MNRAP's Avatar
NCVQ needle (GYT-R needle) at 3 rd clip from top
45 pilot
162 or 165 main
good starting point considering your running the K&N
You will require fine tuning no matter what anyone suggests.. but that should put you in the ball park
157 main, 42 pilot are stock
Old Jun 30, 2004 | 04:57 PM
Yfz450VsBanshee's Avatar
I would put a 165 main. If you keep the stock needle go to the 5th clip.
Old Jun 30, 2004 | 11:33 PM
Dingo2's Avatar
YFZvsBanshee..what about the pilot..45 or 42?
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
clscott84
Sep 21, 2015 10:16 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
