gas tank wet sanding
Old Jun 30, 2004 | 03:01 AM
Loonacy's Avatar
Default gas tank wet sanding
Does anyone have any advice on how to wet sand my 1985 ATC 250r gas tank. I have heard that you can make them look really good by doing this but mine has a very light white colored film everytime I get done sanding it. What grit should I use? Is there a wax or sealer I could use that may help bring out the color. I can not find a new tank so I need this one to look as good as I can.
Old Jun 30, 2004 | 11:56 AM
hondawontdie's Avatar
Ok heres the deal
Use 800 or 1000 grit paper, rub lightly to take out the little scratches. You will need a buffer/polisher also 3M has buffing compound, this will be required also. you will have to wet the tank with water or spit on the sand paper.
Then use the buffing compund to work out the fine scratches. and use paste wax for a car and wax the tank.
good luck
Old Jun 30, 2004 | 05:00 PM
Wes350x's Avatar
If its plastic buy some plastic renew. It works wonders. If not then sand with 800 then put on a couple of coats of mop-n-glo. That works also.
Old Jun 30, 2004 | 08:05 PM
Loonacy's Avatar
Where can I get plastic renew?
Old Jul 1, 2004 | 12:41 AM
Wes350x's Avatar
I got mine from rockymountainatv.com. Denniskirk sells it too. It works amazing. It puts like a film of plastic wax and shines like new. It gives you everything you need. Sandpaper, steel wool, ect. Its like 20 bucks but I did my whole 350x and back fenders on my 400ex and I still have more than half left.
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
