How do you think my plugs looks??
Old Jul 6, 2004 | 06:40 PM
PlatinumDogg's Avatar
Default How do you think my plugs looks??
Well, i just uploaded my spark plug picture into my page might take a bit....
I just put a new jet needle and seat it in...ran it WOT then killed it...check the plug.....electrode white as ash, and outsides black.....
So, i turned the gas/air mixture screw out 1 turn, and now it looks like ok..some what rich maybe...i dunno
What do you guys think??
Old Jul 6, 2004 | 06:51 PM
craZ400's Avatar
I've seen that combo before, where it was rich, then I changed some settings and it leaned out causing the white electrode, but still carboned from before.
Old Jul 6, 2004 | 09:15 PM
Well, i pulled the plug out, and its ash white again..havent adjusted anything, but i think the an exhuast leak may be the culprit...i will patch that up and update here
Old Jul 6, 2004 | 09:25 PM
dzzy's Avatar
If you replaced the needle jet set with OE Honda parts, my experience has been they are plenty lean even with a stock engine. Usually a mixture screw adjustment (richer) is adequate, but there have been times I've richened the needle a slot. As the needle jet wears you will probably have to undo those adjustments as it will tend to get richer as the hole gets bigger from the needle sliding up and down in it, but that probably takes awhile. With your mods, you may want to try to jet up a size or two from stock. Anyway, trying to rejet those old 185 - 200 engines by reading the spark plug is iffy at best. You're better off going by seat of the pants.
Old Jul 6, 2004 | 10:50 PM
Doctorturbo's Avatar
GOT BOOST!
That plug looks miles rich to me. Not even in the ball park. The Poncho looks right on the money though!!! [img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img]
Old Jul 6, 2004 | 10:58 PM
ok..i sealed my exhaust up right good...ran it hard for a bit, then ran WOT for about 30seconds in fifth..pressed the gear shifter down and held it...stopped the engine, then checked the plug....the outside is like before, and the electrode is all white with *some* tan around the top of it..the protruding piece of metal over the electrode has white/tan on about half of it, like right over top the electrode..i think this is ok...what do u guys think...ill post a pic when the plug is cool enough to touch[img]i/expressions/face-icon-small-happy.gif[/img]
Hankey Pankey
May 1, 2018 01:33 PM
Shainasmash
May 8, 2017 06:38 PM
frostphase
Aug 19, 2015 07:11 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
Captjay
Jul 23, 2015 12:33 PM
