04 blaster warning lamp
Old Jul 8, 2004 | 12:16 AM
busmechanic's Avatar
Default 04 blaster warning lamp
I just did the ten hour oil change on my sons new blaster. oil light went out when we first started it. took it out for a ride. and as soon as it warmed up. the light came on. it will stay on for 30 sec. to 1 min. then shuts off. then comes back on in the same amount of time. we used 10-40 yamalube. and its full in the sight glass. I know its under waranty. but, I was wondering if there is a comin problen.
Old Jul 8, 2004 | 12:45 AM
2000IAWarrior's Avatar
change oil in a blaster.. u mean the gear oil.. and dont u use gear oil and not like regular motor oil..
also been a while since ive been around a blasty but i do know they are oil injection is the oil light for the injeter oil.. all i rember it had a neutral light and mayb a oil light or was it temp light i cant remeber for sure.. but check your injector oil.. and make sure you use injector oil in it.
Old Jul 8, 2004 | 02:21 AM
yea trans oil change. the light is temp and oil. is that for the injection oil? or trans oil? (the light)i thought it was for the trans. I guess it could be for the 2 cycle tank. I will look to see if there is a sensor on the tank. I know it is still about half full or so.
Old Jul 8, 2004 | 01:34 PM
BLASTPASTYOU200's Avatar
ya i have an o4 blaster 2 and it happened to me cuz when the tank is just under ha;lf full its telling you to put oil in, its definetly to early for an oil punp faliure known to happen on blasters but an oil injection block off kit is a mus after a wile, also sometimes when im going down steep hills i hold the clutch wile im in gear and just roll and it goes on but shuts off asoon as i give it gas. hope this helps
Old Jul 16, 2004 | 04:57 AM
dirtybayblood05's Avatar
i gots an 04 blaster and the red light on it is for the oil injector so jou might wanna check that out on it what jou said never happened to me tho
Old Jul 16, 2004 | 10:38 AM
yea, I am a dumb a**. sensor in the tank. we had a lt80. but it did not have any light or sensor in the 2 cycle oil tank. and the tank is still at least half full. I really did not want to carry another gas can around. I geuss I will have to eventually. or bypass that sensor. so it only works for temp.
Jeff Roper
Feb 1, 2022 11:48 AM
panicmanic
Sep 28, 2015 12:59 PM
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Schneider
Jul 24, 2015 05:05 PM
