700 sportman shifting problem
Old Jul 16, 2004 | 08:47 AM
ND's Avatar
ND
Default 700 sportman shifting problem
I've got my father-in-laws sportsman 700 while he is out of the country. I believe its an '03. I don't have an owners manual for it and have no real experience with polaris atv's. The problem is that its a total pita to get it to shift into park. Is there some trick to this? Or is the shifter just clunky no matter what?
Old Jul 16, 2004 | 09:27 AM
emmerth's Avatar
You got to step on the foot emergency brake. Its on the right side. Then with the brake depressed, it'll slide right into park.
Old Jul 16, 2004 | 11:10 AM
jimmypsp700's Avatar
That's right and it is notchy though and can be tough, just use the foot brake for all shifting, you must use it out of low, it will only go between rev. and low without the foot brake for plowing ease.
Old Jul 17, 2004 | 05:32 AM
ND's Avatar
ND
I'll try tomorrow, thanks for the replies..
Old Jul 17, 2004 | 08:38 PM
Jack3689's Avatar
Also check that the bracket that attaches the shifter to the frame (the pivot point) isn't loose. My 2002's worked itself loose once and bound up the shifter just like you are describing.
Old Jul 17, 2004 | 11:01 PM
slags56's Avatar
there should be a decal that says depress foot brake to shift into high or park.
heath legg
Jul 24, 2015 01:01 PM
hondarider1234
Jul 21, 2015 11:53 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
sara durrant
Jul 6, 2015 05:32 PM
