cracked frame
Old Jul 18, 2004 | 08:18 PM
thewayout420's Avatar
Default cracked frame
hi guys,i was just looking at my stripped machine and noticed the cross piece that holds the upper motor mount and the fuel tank mount is broken,one side is cracked and totally broke from the frame and the other side is starting to crack..there really isnt anyway of welding it and having it be strong,think i should put some gussets on each side of it?if somebody could look at theirs and see if they can come up with a good fix id appreciate it,thanks..
Old Jul 18, 2004 | 09:06 PM
tbsleeper's Avatar
dou mean the piece that goes from one part of the frame to the other? or the motormount itself. i would say if u weld it it willbe stronger than it was stock
Old Jul 18, 2004 | 09:17 PM
its the piece that goes across the frame rails,the the upper motor mount is on the under side and the rear gas tank mount bolts to the top.i can weld it but the way the piece is made and the way its broke isnt going to make for a strong weld.im thinking i have to weld it and add gusset's..
Old Jul 18, 2004 | 09:21 PM
tbsleeper's Avatar
ino where ur talking... how would that break!! i was thinking of cutting mine to save a lil weight
Old Jul 18, 2004 | 09:25 PM
the piece is needed for the motor mount,so getting ride of it isnt a good idea..im not sure how it broke or what would have caused it?
Valder
Nov 28, 2020 07:38 AM
EIF
Apr 20, 2017 07:15 PM
franklyme
Oct 21, 2016 07:18 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
greg86hd
Sep 16, 2015 12:32 AM
