USFS run in
Old Jul 20, 2004 | 06:38 PM
Hez's Avatar
Hez
Default USFS run in
So I just received my Mr.Hp endcap and was taking it for its initial ride. On my way back to the truck a USFS guy stopped me and asked if i had a spark arrestor. I knew I didn't but let him do his test anyway. He said he wasn't going to write me a ticket but would file it as an Incident report and hand it off to someone else. I'm thankful for that.
SOOO... Do I need a USFS approved spark arrestor for say Glamis, Pismo (Oceano), Dumont or any other place in the dessert? If so where do you all ride with your Mr.Hp endcap that doesn't require a spark arrestor? Or would it be worth it to sell the newly aquired endcap and buy an HMF?
Thanks in advance.
Hez
Old Jul 20, 2004 | 06:44 PM
OuterLimit's Avatar
Default USFS run in
Technically you need a spark arrestor on any goverment land (BLM, national forest, national parks, etc). I haven't needed one at Dumont, Little Sahara (UT), or St. Anthonys though.
Old Jul 20, 2004 | 06:45 PM
DSengineer's Avatar
Has been here a long time!
Default USFS run in
Most dunes do not require a spark arrestor. At least the ones you have listed.
Any US forest, SVRA, or OHV that is located in grassy forest conditions will require a spark arrestor however. During the winter months you may get away with out it but it is so dry out there right now they are probably cheking pretty hard. I currenty have the end cap but can really only use it at the dunes so I plan on purchasing an HMF slip-on in the near future.
Old Jul 20, 2004 | 07:18 PM
04DS650's Avatar
Default USFS run in
You're probably lucky that they didn't do a sound check too. I doubt a Mr HP endcap would pass that test.
Old Jul 20, 2004 | 07:22 PM
1BADRAPTOR's Avatar
Default USFS run in
if you ride anywhere in california you are required to have a spark arrestor dont mean im going to throw it on..
Old Jul 20, 2004 | 07:25 PM
DuneMe's Avatar
Default USFS run in
It has been a while since I checked the HMF site but, when I was looking they didn't offer a USFS pipe. Worth a double check before you order your pipe.
Old Jul 20, 2004 | 07:40 PM
Cammer's Avatar
Default USFS run in
I have the Mr.HP endcap and I have put the $5 Target strainer screen inside the pipe and have had no problems with the spark arrestors (bad pun).
Old Jul 20, 2004 | 08:20 PM
DSengineer's Avatar
Default USFS run in
How did you attach the screen to the inside? Any pics?
Old Jul 20, 2004 | 08:23 PM
DSengineer's Avatar
Default USFS run in
http://www.hmfengineering.com/quietcore.html
Old Jul 20, 2004 | 08:43 PM
Hez's Avatar
Hez
Default USFS run in
The screen sounds like a good idea. All the guy did was stick a pencil in the exhaust hole. And for the HMF can you get a USFS spark arrestor w/o the quiet core?
Thanks again guys.
