Warped pvt cover 325 trailboss.
Never had that happen to mine. Is the air intake to the clutch clogged anywhere? Comes in from the right side cover just below the tank. Sounds like that may be the problem, and the heat is building up. If you ride double, make sure someone isn't using the cover as a footrest.
This is pretty common for the Trail Boss....and other models that used the same clutch cover for years prior to the '02 TB redesign. I just replaced my wife's '00 TB clutch cover with the beefier '02 model. What's cool is that it's $10 cheaper. You'll need to come up with something to neck up from the 2" vent tube to the 2-7/8" intake on the '02 model cover, though.
carid
Sep 14, 2015 03:40 PM
