Help..front brake lever
Old Jul 21, 2004 | 12:03 PM
clover's Avatar
Default Help..front brake lever
My front brake lever has about an inch of free play and there shouldn't be any,does anyone know how to tighten or stiffen it up?
Old Jul 21, 2004 | 12:38 PM
duke9074's Avatar
the adjustment screw like a bike is next to the lever.
Old Jul 21, 2004 | 12:50 PM
TheRaptorMan's Avatar
Is it loose or does it feel like it has air in the lines? If it is just real easy to pull back and then gets stiff then it may be air in the line... It makes the brakes feel "spongy"
Old Jul 21, 2004 | 01:14 PM
clover's Avatar
yeah it goes back about an inch then gets stiff so there maybe air in the lines.Is there a way to fix this?
Old Jul 21, 2004 | 01:16 PM
Is this a new quad? If so and you haven't worked on the brakes, I would take it back and let the dealer fix them. If you have air in the lines you will have to "bleed" the brakes and if you have not done this before I would let the dealer do it.
Old Jul 21, 2004 | 01:52 PM
Eric250EX's Avatar
its a disc break so no cable.
but anyway try bleeding your break lines, should fix the problem
Old Jul 21, 2004 | 01:54 PM
clover's Avatar
alright thanks everybody,i'll just bleed the brake lines.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
tysonbully
Sep 28, 2015 02:30 AM
oliveiracarlos
Sep 7, 2015 03:39 AM
