Gearing?
Old Jul 22, 2004 | 12:50 AM
bLuRRRR27's Avatar
Default Gearing?
I am geared 13/40 stock with a 300 dollar Sidewinder setup...i dont really want to go to a 41 or 42 in the rear only because it will run me a bill50 just for the rear sprocket being that it is TIMoly... the front is much cheaper and i am considering dropping to a 12.... Will i be hit on top end speed or will i only loose 8-10mph...
Will my gears be rediculously short???
Should i eat it and just go buy the 41 for the rear like i want to do...
-bLuRRRR27-
Old Jul 22, 2004 | 12:52 AM
bLuRRRR27's Avatar
Default Gearing?
I ride tighter trails and end up usin my clutch way to much!
Old Jul 22, 2004 | 03:36 AM
pinheadedjoker's Avatar
Default Gearing?
just drop the front tooth sproket a tooth.. youlll notice a big diff in accel.. not as big for the speed.. i barely noticed the differnce in top speed when i put it on.. plus it is way cheaper.. and its like having a 13/43 gearing.. but its 12/40 [img]i/expressions/face-icon-small-smile.gif[/img] or sumthing like that.
Old Jul 22, 2004 | 11:15 AM
Dfitz's Avatar
Default Gearing?
Before you go spending big bucks buy some cheap steal sprockets and see what you like.
Old Jul 22, 2004 | 12:19 PM
TheRaptorMan's Avatar
Default Gearing?
Thats what I was going to say, buy a cheap gear and try it out... Heck I still run the cheap ones LOL If it ain't broke don't fix it!!!
Old Jul 22, 2004 | 12:24 PM
garyc660R's Avatar
Default Gearing?
Originally posted by: TheRaptorMan
Originally posted by: DfitzBefore you go spending big bucks buy some cheap steal sprockets and see what you like.
My thoughts exactly. Even cheap sprockets hold up great as long as they are steel. Just go down 1 in front would be my opinion. 1 tooth more in the rear would not even be noticable.
Gary
Old Jul 22, 2004 | 12:29 PM
Default Gearing?
You know like Gary said one tooth in the back would be miniscule I would go two at the very least...
I mean think about it...
13/40 = 3.08 12/40 = 3.33
13/41 = 3.15 12/41 = 3.42
13/42 = 3.23 12/42 = 3.5
Just try it with the cheapos and take it from there.
Old Jul 23, 2004 | 02:23 AM
bLuRRRR27's Avatar
Default Gearing?
Thanks alot u guys, i KNOW i can go buy wut u say due to the experience you both have...
I am going to go with the Sidewinder 12 tooth front...i start getting shaky around 80ish...therefore i could afford to loos my top end some only because the only time i really top it out is on the road!
I dont think my front tires are balenced that well i am runnin the .190's with XCR's...and on the road its just to unstable, i may have a loose front hub or somethin that i outta check!
How much top end will i loose, with the 12 front...8-10mph....will my gears like 1 and 2 be useless????(rediculously short)
I know you are going to just say try different gearing but i think i will be happy with just doin the front and to tell u the truth actually i knowticed a difference with the 41 in the rear......i could launch way better in 2nd, and my 1st gear was really short, it was like a creeper gear lol
Like i said thanks for ur suggestions,
-bLuRRRR27-
Old Jul 23, 2004 | 10:12 AM
Dfitz's Avatar
Default Gearing?
I run 12/42, I tried just the 12 up front but it never seemed quit right. So I started playing with the rear and that made a night and day difference. You talk about loosing top end, you loose some top end but you power to the top so much faster. The only real way to see what you will like is to play with it.
lonerider856
Oct 13, 2023 03:45 PM
Honski250r
Sep 26, 2015 09:40 PM
patrick.oc123
Sep 15, 2015 02:45 PM
bigbear350quad
Sep 11, 2015 12:40 PM
awer1968
Sep 8, 2015 11:02 AM
