is this a problem?
Old Jul 22, 2004 | 10:18 PM
eastcoastscrambler's Avatar
Default is this a problem?
after taking my seat off my scrambler and lifting the cover to the filter which was quite dirty i noticed oil and the bottom of the tank, i'm not sure if that should be there or not. Also i noticed a little crack in the seal of the cover, as u probablly already guessed i know nothing about 4 wheelers and i am very worried about this, is it a major problem? thanks.
Old Jul 22, 2004 | 11:07 PM
BigBadScrambler's Avatar
Have you flipped your machine or had it standing up on end at all? This will cause some oil to get in the air box. Nothing to worry about. There is a sediment drain tube on the bottom of the air box. Pull the plug and clean out the air box.
Old Jul 23, 2004 | 04:17 AM
WileyCoyote's Avatar
My Prairie has oil in the air box regularly. I was a little alarmed until I realized everyone else gets oil in their air box too. I stopped worrying about it.
Old Jul 23, 2004 | 03:06 PM
i didn't flip it, i did wheelie it however, that's probablly why, but it drained by it's self.
Old Jul 25, 2004 | 02:21 PM
Its probably in the sediment tube. Dont worry about it
Old Jul 25, 2004 | 02:28 PM
yzbluebeast631's Avatar
The oil comes from the case breather. The breather tube is routed to the airbox. You will get oil in the airbox if you stand the quad on end, roll it over or if the case is over filled.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
