2005 Grizzly low speed
Old Jul 24, 2004 | 11:54 PM
sledge48593's Avatar
Default 2005 Grizzly low speed
i took out my new 2005 grizzly today got it stuck in some mud up to the fenders when i got it out i pulled the drain plug for drive blelt about a half gallon of mod water came out belt sliped for a little bit but i have lots of power and torque but it only goes about 20 mph like it is stuck in low gear had 4x4 in plus diff lock when got stuck no rev limmiter probs eccept when it hit very high rpm kinda ticks me off only had it 5 days new to utilty quads have a raptor not used to auto clutch probs yet tnx help!!
Old Jul 25, 2004 | 12:05 AM
Rider1169's Avatar
i had an old suzuki and i sunk it a lot, on the ride home i could only top out at lik 10 mph. all it was is there is just much water in the transmisson oil. i drained it, then ran it for a minute, then drained it, and repeated that until nothing came out, then u add the amount of oil it takes and i was good again. that might be whats wrong with urs. if requires more than one draining usually
Old Jul 25, 2004 | 09:05 AM
BABYCAKES's Avatar
Take your cluch cover off ( not a big deal). You'll find it will have fine mud packed probably packed in side the cluch. Happy trails!
Old Jul 25, 2004 | 05:39 PM
shaolinfox's Avatar
hey sledge48593 you have a more serious problem than you think..the two black tubes that lead from the transmission aare clogged with mud and not allowing the belt to expand properly...I experienced the same thing on my 02grizz..the mud got in thru the front end,there is a hole for air to get in right under the front racks and if mud gets in there it will clog the airways to keep it cool.same for the rear if the if you dont find it in the front..the rear hose is the release the air.if its not breathing right the belt cant stretch and you cant get any speed..it cost almost 350bucks at the dealer...its something you do yourself,but i would let them go head do it right...[img]i/expressions/face-icon-small-cool.gif[/img]null
Old Jul 25, 2004 | 10:54 PM
batmanacw's Avatar
The plug on the servo in the front diff may be shorting out. I would pull it out and put dielectric grease in it and see if that helps.
Old Jul 26, 2004 | 12:14 AM
Andy Bassham's Avatar
yep, your transmission could be packed with mud or you could have tripped out that thing that limits the speed when the differential is locked. Had a friend have that problem. Something in the servo screwed up and it would only go 22 regardless of high or low range or even 2wd.
Old Jul 27, 2004 | 08:54 PM
Wow did I pack some dirt in there dug out about 2 cup fulls of hard pack dirt out of v-belt clutch and it fixed the problem Thanks alot guys for the feed back helped a ton
Old Jul 28, 2004 | 08:34 PM
Vakero's Avatar
If there was water/ mud behind crankcase cover # 3 (the first cover that houses the primary and secondary sheaves), then there is most likely trapped water/ mud behind crankcase cover # 2
(the second cover behind the pri & sec sheaves). The only way to remove trapped water behind CC-cover # 2 is to remove it and wipe the water out. It might be worth while to remove this second cover to check because it houses the clutch housing and carrier assembly. Also, If you haven't cleaned and repacked the primary sheave with "Grizzly Grease" and your secondary sheave with Bel-Ray assembly lube you may be on your way to more costly repairs. A service manual CD will show you how to do the work and it will cost less than $20 for the grease and lube. The job should take less than 2 hours to complete.
Old Jul 28, 2004 | 09:23 PM
Grizz05owner's Avatar
I did the same thing except with clean water, no mud. I was able to pull the drain plug and drain it out and a few minutes to let the belt dry and I was on my way again. I was crossing a river and hit a hole sinking the quad over the seat and the only thing sticking out was the handlebars. I accelerated a tad and the front end lifted up doing a wheelie under water and that raised the tank a bit out of the water so I didn't drown the engine also. I was able to go in alot deeper of water that way riding my wheelie lol
The reason I responded though was to make sure you knew you could hold in the grey override button and get full lockup past 20 mph. If you don't hold the button the the full lock up will automatically go to the limited slip 4 wheel once you get past 20 mph.
Old Aug 17, 2004 | 02:51 PM
shane8303's Avatar
If you swamped your belt case you HAVE to clean and re-lube your primary clutch or you will ruin it.
mywifesquad
8
Sep 21, 2015 08:20 AM
rawbdiggity
Sep 7, 2015 12:05 PM
Elkaholic
Sep 6, 2015 02:44 PM
Brandon400
Sep 5, 2015 08:44 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
