300ex not starting now
Old Jul 26, 2004 | 03:05 PM
manual's Avatar
Default 300ex not starting now
Well I went to start up my quad. Pulled in the clutch and press in start, so I hear buzzzzzzzz than pop! I heard that with how much comprsesion they have been known to blow starters, so I took off the starter, removed all the gears and they looked fine. So I contacted a site and he told me to look at my one way, so I open up my left crank case cover, after removing the reverse lever, and all other required parts. At this point everything looked fine but I noticed everything scooted foward which made the starter miss the one way, so I pushed it all back, and closed the crank case seeing if this would be the differnce. I plugged back in the 2 electrical connections and went to start it. Nothing, so I went to get a battery jumper that has a charge and tried seeing if my battery was dead it still didn't start with a battery jumper on it. Im wondering if it has something to do with a reverse lever. I didn't play around with it though is the thing so I don't know why it would do that.
Old Jul 26, 2004 | 04:31 PM
TLR200REFLEXBandit's Avatar
Ummmmm I know you get a buzz noise out of the starter with a almost dead battery, the starters are honestly tanks, but if your bike is really well used I guess it could be something wrong with it. The pop noise is weird though. dunno what else to say. They bum start fairly easily, but that isn't really very fun
Old Jul 26, 2004 | 04:55 PM
300exRiderJay's Avatar
Are any lights coming on? Like the neutral or headlight? If not, replace you fuse (they give you an extra one) and then see if it turns over again.
Old Jul 26, 2004 | 05:08 PM
manual's Avatar
Headlight is removed, and checked fuses already. The thing is now its not even doing anything. Before the starter would just free spin, now its doing nothing. You will press the start button and it does nothing.
Old Jul 26, 2004 | 11:05 PM
manual's Avatar
anyone know?
Old Jul 27, 2004 | 12:55 AM
Tbuck89's Avatar
I had a similar problem...but mine was wiring, and my solenoid was bad, it was the exact same problem you stated, after puting a test light screwdriver into the one of the wires and pressing the ignition button it started...but I dunno...Sorry man[img]i/expressions/face-icon-small-sad.gif[/img]
Old Jul 27, 2004 | 12:13 PM
Matt37's Avatar
i had this problem on mine when you pressed the start button it sounded like stuff was grinding up inside there and mine was my starter clutch it was bad
fullprice54
Jun 18, 2015 09:44 AM
NONEtooSMART
Jun 17, 2015 08:48 AM
Hondaislife
May 28, 2015 01:43 PM
Hondaislife
Sport Quads
May 27, 2015 05:38 PM
1000gade
May 27, 2015 12:37 PM
