Installing Reed Spacer
Old Jul 26, 2004 | 05:10 PM
silentdeath489's Avatar
Default Installing Reed Spacer
I read somewhere that you can install a reed spacer in 1 of 2 spots for different performance. Is this true and if so can comeone explain?
Thank you.
Old Jul 26, 2004 | 06:05 PM
anyone?
Old Jul 26, 2004 | 06:13 PM
hondaguy13's Avatar
no it is not true the reed spacer goes in front of your reed cage to pull the reed cage farther away from the sleeve
Old Jul 26, 2004 | 07:02 PM
ok.. thank you.
Old Dec 7, 2004 | 06:51 PM
Semms40oz's Avatar
in the process of doing a search for something related and felt i had to correct this info.
a reed spacer can be installed to either push the carb farther away from the reeds or move the reeds farther away from the cylinder. Depending on how it is installed it changes performance in a different way and that is what i'm searching for since i no longer remember
ReconBayou
Oct 31, 2022 05:37 PM
QuadRiders
Oct 22, 2015 04:13 PM
2many2ride
Sep 27, 2015 04:35 AM
toonces
Sep 5, 2015 01:14 PM
