Please help! FAST!!!! (Warrior Pilot Air Screw Adjustment)!!!
Old Jul 27, 2004 | 10:05 PM
Jordanw's Avatar
Default Please help! FAST!!!! (Warrior Pilot Air Screw Adjustment)!!!
i am selling my warrior, i am giving it one last quick tuen up. i am reading in my repair manuel and i no how to do it but in the manuel it says to have the Pilot Air Screw 2 turns out, i have a k&n and a supertrap exaust, would it still b to screws out if not how many???¿
thanx a lot [img]i/expressions/face-icon-small-wink.gif[/img]
Old Jul 27, 2004 | 11:06 PM
Jordanw's Avatar
bump
Old Jul 28, 2004 | 10:28 AM
95wolv's Avatar
Best way to set the mix screw is to warm up the motor, then run it up to speed in 2nd or 3rd gear, then let off the throttle without touching the clutch, if the motor pops or backfires a litttle, open up the mix screw a quater turn, then retest. Once you can let off the throttle with no pops as you coast, it should be set right. If you need to go out more than 3 1/2 turns, you may need a bigger pilot jet.
Old Jul 28, 2004 | 10:54 AM
Jordanw's Avatar
ok, how do u no when it isn't turned out enough? thanx
Old Jul 28, 2004 | 11:43 AM
95wolv's Avatar
As stated in my first post, if it pops or backfires on decelleration, you need to turn it out a little at a time until the popping stops.
Old Jul 28, 2004 | 02:49 PM
04Raptor350Guy's Avatar
Good advice!
Old Jul 28, 2004 | 03:37 PM
hondabuster's Avatar
The two turns out is a starting point. You have to fine tune it from there. Screwing out, is richer, and turning in is leaner. This adjustment, will only effect the idle circuit.
Heres a good article on carb adjusting.jetting You might find it helpful.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Ramman1
Jun 16, 2016 09:07 PM
dougn85
Aug 5, 2015 07:20 AM
Aitch
Jul 21, 2015 09:40 PM
