wolverine jetting......what kind of head?
Old Jul 29, 2004 | 04:38 PM
Rock777's Avatar
Default wolverine jetting......what kind of head?
I just ordered a supertrapp IDS2, amsoil air filter w/ uni-vents in airbox lid, and am planning on putting a different main jet in. When I called a few different yamaha dealers to order one, they said they needed to know what kind of head the jet had (hex, round, flat). I have no idea and was hoping some of you warrior/wolverine owners who have rejetted could enlighten me. I thought this was something they could look up in a book but I guess not. I think I am going with a 145 main jet for starters, does this sound about right, my wolv is stock before I put the above mods on.
Old Jul 29, 2004 | 05:41 PM
Lucky13's Avatar
you have a large round mikuni head. Buy a couple of different size jets(they are cheap) it will save you time running around. Good luck
Lucky13
2001 wolverine
high comp piston wiseco
white brother cam and e-series exhaust
heavy duty valve springs
re-jetted
pro-flo K&n filter kit
warn 424
(clutch mod coming soon)
Old Jul 29, 2004 | 07:59 PM
Rock777's Avatar
Thanks alot Lucky, you saved me from having to take my carb off first, which means I can't be riding it while the jets are out.[img]i/expressions/face-icon-small-wink.gif[/img] I appreciate your help
Old Jul 29, 2004 | 11:13 PM
OhHell's Avatar
I believe I would start with a 150 instead of a 145. I am running a 155 with my mods.
Old Jul 29, 2004 | 11:52 PM
Deimos's Avatar
Is there not a little bit more science or engineering to this....or do you just slap in jets till it seems to sound and run good? Serious...I would like to do some mods myself, but if guess work is involved, I think I'll pass on anything that requires rejetting or at least till the newness wears off. Im a chiller and boiler mechanic which involves electric motors pumping fluid or gas, little bit different then the combustion engine but everything is precise and has measurements. No guess work involved. I would of figured combustion engines would be the same, but I dont know. Pretty new to me. Still learing all this stuff, which makes it half the fun. Good luck.
Old Jul 30, 2004 | 11:05 AM
Lucky13's Avatar
run the machine for a few miles, get a little color on the spark plug. Then try to get in fifth gear, hold your shifter down, coast, and kill the motor. Check the plug again(the white ceramic around the firing portion on the plug), if white, go larger. if really dark, go smaller. Best size should run fastest. Color should be a light golden color, if properly jetted. Sound has nothing to do with it. It's not that hard, just need some patience testing it out.
lucky13
speedbuff
13
Nov 11, 2020 10:16 AM
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
fordfaithful21
Dec 7, 2015 05:52 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Minimod
Sep 10, 2015 08:03 AM
