replacing rear bearings on a 99 400EX
Start the process by loosening up the two nuts just to the right of the brake rotor. It will help if you have someone help hold your rear brake pedal down. If not, pump it up and use a strap.
Loosen the larger lock nut first and the the bell-shaped nut. Once you have these loose, loosen the right rear hub nut.
Then you can take the brake caliper off and finish the getting everything else apart.
/Jon
/Jon
Rooky
10
Jun 23, 2015 09:35 PM
