raptor reverse problem
Old Aug 9, 2004 | 01:05 PM
660rollover's Avatar
Default raptor reverse problem
sometimes when i shift into reverse, it seems like it doesn't go all the way into reverse and makes this sound like the gears are spinning and the tips of the gear teeth are barely touching each other. when i hear it, i push down on the shifter and it goes into reverse fully, but i'm thinking to myself that this can't be right. does anyone else have this problem or know how i can fix it? am i shifting into reverse correctly?
Old Aug 9, 2004 | 01:16 PM
Lomax's Avatar
Mine does it when i dont make a good solid shift. I dont know of any real fix for it though
Old Aug 9, 2004 | 01:35 PM
mikeg1005's Avatar
I got the same thing going, I don't think there is anyhting wrong, it just seems to happen when I don't shift fully down when I twist the reverse ****. Usually doesn't happen though.
Mike.
Old Aug 9, 2004 | 02:05 PM
mine will do it about every 4th time or so. i just don't want to buy a new trans because i'm doing something wrong
Old Aug 9, 2004 | 02:16 PM
bpotter's Avatar
The gears are not lined up....Just keep your foot lightly pushing down on the shift lever while you slowly release the clutch. You will feel it click into reverse gear and then you are good to go!
But don't force it in while the everything is turning fast because you will break something!
skinnyr6
Aug 25, 2023 02:18 AM
Reactant
Mar 30, 2022 02:08 AM
Scottma518
Jul 10, 2015 12:42 AM
yambam13
Jul 4, 2015 01:49 PM
bikedad3
Jul 2, 2015 02:15 AM
