raptor reverse problem
Old 08-09-2004, 01:05 PM
660rollover's Avatar
Default raptor reverse problem
sometimes when i shift into reverse, it seems like it doesn't go all the way into reverse and makes this sound like the gears are spinning and the tips of the gear teeth are barely touching each other. when i hear it, i push down on the shifter and it goes into reverse fully, but i'm thinking to myself that this can't be right. does anyone else have this problem or know how i can fix it? am i shifting into reverse correctly?
Old 08-09-2004, 01:16 PM
Lomax's Avatar
Mine does it when i dont make a good solid shift. I dont know of any real fix for it though
Old 08-09-2004, 01:35 PM
mikeg1005's Avatar
I got the same thing going, I don't think there is anyhting wrong, it just seems to happen when I don't shift fully down when I twist the reverse ****. Usually doesn't happen though.
Mike.
Old 08-09-2004, 02:05 PM
mine will do it about every 4th time or so. i just don't want to buy a new trans because i'm doing something wrong
Old 08-09-2004, 02:16 PM
bpotter's Avatar
The gears are not lined up....Just keep your foot lightly pushing down on the shift lever while you slowly release the clutch. You will feel it click into reverse gear and then you are good to go!
But don't force it in while the everything is turning fast because you will break something!
skinnyr6
08-25-2023 02:18 AM
Reactant
03-30-2022 02:08 AM
Scottma518
07-10-2015 12:42 AM
yambam13
07-04-2015 01:49 PM
bikedad3
07-02-2015 02:15 AM
Quick Reply: raptor reverse problem
