warrior problem plz help
Old Aug 11, 2004 | 02:40 PM
95warriorrider's Avatar
Default warrior problem plz help
i have a 95 warrior and it burns oil quick i even tried that yamalube and it still went in like 2 weeks. my friends dad said it was the rings but idk
Old Aug 11, 2004 | 02:42 PM
04Raptor350Guy's Avatar
Does it smoke badly?
Old Aug 11, 2004 | 02:44 PM
no but the exhaust smells really bad
Old Aug 11, 2004 | 03:11 PM
It might be the rings....
Old Aug 11, 2004 | 03:35 PM
moldycheese's Avatar
u better HOPE its just the rings. my 99 warrior ha to have 2 re-builds when we thought it was just the rings (cause was the crappy airbox, and airfilter)
Old Aug 11, 2004 | 03:54 PM
warrior68man's Avatar
Try to run lucas engine restore. Mine smokes at high RPMS but it used to smoke all the time, then I dumped a little bit in there and it seem to stop at low and mid rpms but when I'd rev it high I'd see some white smoke. That's should stop it from doing it a little. Check around your valves. May be the valve seals leaking. It could be alot. But also make sure your airbox is clean along with your air filter.
Old Aug 11, 2004 | 04:13 PM
Gwinnwarrior's Avatar
i run lucas oil addatives in all of my machines as well. i have a grand prix with 130K on it and it doesnt burn a single ounce of oil between changes. i also run it in my 89 warrior and havent had a single motor problem .. not one! doesnt smoke or burn oil. i would highly reccomend it, it costs a little bit but it definately is the best thing you can do to maintain your engines life. try it and let us know!!
Old Aug 12, 2004 | 02:29 PM
thanks for the help ill try the lucas stuff
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Reactant
Jul 16, 2015 10:29 PM
