stripped bolts
Old Aug 17, 2000 | 03:20 PM
evan99's Avatar
Im trying to put a new axle on my 87 honda 250r trx the nut on the right hub is stripped also the threads on the hubs have made a groove in my rim so that wont com off any sugestions on how to get these off. tried eveything
Old Aug 17, 2000 | 05:05 PM
hot_shoe_cv's Avatar
I don't know if a nut breaker is made in a big enough size to fit the stripped nut. You might check that out. If not possibly cutting the nut with a power hack saw or even a manual one would be an option. Not being familiar with the hub's shape in relation to your rim on the R, I'd have no clue to that problem
Old Aug 18, 2000 | 11:25 PM
sl250r's Avatar
i had a problem with that on my lakota i took a pair of chanel locks and clamped the back of the stud to the wheel and the nut came right off
Old Aug 20, 2000 | 11:57 PM
KawasakiKid's Avatar
I purchased Metrinch. Yeah I know it sounds cheesy, but it's a life saver when it comes to switching back and forth between Standard, Metric, and the occasional rounded / stripped.
You would be amazed what I've been able to take off with it. I wouldn't give it up for anything! Money well spent in my opinion. The set can be bought at Sears starting around $100.
Old Aug 22, 2000 | 08:42 PM
92LT's Avatar
evan99, I had the same problem on a 250r that I was working on. I ended up using a dremel tool (or air die grinder) with a thin cutting disk and cut the nut off. If you take your time, you shouldn't mess up the threads on the axle.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
tysonbully
Sep 28, 2015 02:30 AM
firsttimerider
Sep 20, 2015 09:07 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
