87 Warrior neutral relay
Old Aug 12, 2004 | 03:52 PM
shaunstickler's Avatar
Default 87 Warrior neutral relay
I have an '87 Warrior. The neutral light will not come on when the battery is connected. I believe that it is the neutral relay. There is power all the way up to the relay. Does anyone know how to test this relay?
Old Aug 12, 2004 | 04:05 PM
04Raptor350Guy's Avatar
Maybe the bulb is burnt out[img]i/expressions/face-icon-small-tongue.gif[/img]
Old Aug 13, 2004 | 04:38 PM
Blaster96's Avatar
I know my netural relay did not work on my 87 warrior. Heck neither did the reverse relay or starting relay. New ones would not work either.
If you jump the relay does the light come on?
Old Aug 13, 2004 | 07:41 PM
How do you jump the relay?
Old Aug 14, 2004 | 01:04 AM
Blaster96's Avatar
simply jab a wire into the lead power to the relay and place the other end to the wire that feeds the light. If the light still does not come on it is blown or has a bad ground. If it does, replace the relay. Prepare your self to pay about $35 for a new relay.
Good Luck!
Old Aug 14, 2004 | 08:08 AM
TrailBlazerguy250's Avatar
Am I gona have to worry about this in the future w/ my 97 ? Or was it just the 87 that did that ?
Old Aug 14, 2004 | 04:22 PM
Blaster96's Avatar
Relays normally dont go out. Sometimes they just quit.
Dont worry about it. Also the new warriors have diffrient relays than the older ones.
Old May 7, 2019 | 10:49 PM
518bikelife's Avatar
Default My 2001 yamaha warrior 350
Hello, can someone please help.....I have a 2001 Yamaha warrior 350, neutral light keeps going out every time I try to start it, now won't start. But I keep hearing a buzzing noise every time I press the ignition. Could the problem be my "Neutral relay"
Please help!!!!!
Old May 8, 2019 | 01:38 AM
Flat battery or bad battery connection.
95wolv
Sep 27, 2024 12:00 PM
2many2ride
Sep 27, 2015 04:35 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
