Grizz using oil
Old Aug 24, 2004 | 09:14 AM
Thunderbolt's Avatar
Default Grizz using oil
I have an 04 Grizz with 45 hours on it. At 25 hours I changed the oil and filled it with 0w-40 Amsoil. The machine doesn't smoke or anything, When I checked the oil it was about 3 ozs low. I was told by one dealer this is normal with synthetic while another dealer said I shouldn't be running synthetic yet. Anyone elses Grizz use any oil ?? Is it normal to use a little and should I change back to Yama-Lube ??
I do ride it kinda hard.
Old Aug 24, 2004 | 03:38 PM
Kawi650's Avatar
When you change the oil you should run it and check it again because you need to fill the oil filter etc...
Old Aug 24, 2004 | 09:54 PM
LittleBill's Avatar
your really not suppose to run sythentic yet, i would wait till about 200 miles before switching too syntetic let the engine break in abit
Old Aug 28, 2004 | 10:59 PM
ProEMTPFF's Avatar
Mine uses oil BUT only when I'm on a long open road full throttle. So, if you've been doing that look in your air box for oil. What happens is the crank case vent hose is attached to the air box, when held wide open for a extended time the Grizzly will "suck" oil up through the hose.
1000gade
Sep 19, 2015 10:28 AM
toonces
Sep 5, 2015 01:14 PM
toonces
Aug 3, 2015 09:59 AM
toonces
Jul 23, 2015 02:21 PM
toonces
Jul 16, 2015 03:19 PM
