What Wheels?
I am looking to put the larger 9 inch wheels on the rear of my Blaster. I know i need the adapters to make the bolt pattern the larger 115 size. My question is which wheels would fit it the best? All I will probably ever use the quad for is trail riding and i really just want it to be a little wider and to have a lot more tire options. Plus i hate the factory sized rears. Any suggestions?
Thanks
Derek
Thanks
Derek
The rear bolt pattern is 110 on the blaster, the banshee is 115.
Your best, and probably cheepest option, is to order a set of stock BANSHEE rear hubs and rims. Then you can put the hubs on the blaster and you will have the 115 bolt pattern and 9'' rims.
I just ordered the stuff to convert the hubs. Now i just need to decide on tires and wheels. I am thinking of going with a set of ITP wheels and tires, but don't know what size tire to go with. I don't like the tall tires and don't really ride anywhere that needs a lot of ground clearance.
I think i am pretty set on a set of 20-11-9s. At least then i will have a couple different sizes to choose from with the nine inch wheels. By the way Shav0, what kind of swingarm and rear shock do you have? I want one sometime in the next year or so, and am starting to look around for one.
What about your axle, are you still using the stock one? I don't know how much more width i will need when i have wider tires and spacers on the stock one. I also don't want to get into new front a-arms to widen that out right now.
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
