What Wheels?
Old Aug 25, 2004 | 12:07 PM
DRoCk's Avatar
Default What Wheels?
I am looking to put the larger 9 inch wheels on the rear of my Blaster. I know i need the adapters to make the bolt pattern the larger 115 size. My question is which wheels would fit it the best? All I will probably ever use the quad for is trail riding and i really just want it to be a little wider and to have a lot more tire options. Plus i hate the factory sized rears. Any suggestions?
Thanks
Derek
Old Aug 25, 2004 | 12:43 PM
Shav0's Avatar
The rear bolt pattern is 110 on the blaster, the banshee is 115.
Your best, and probably cheepest option, is to order a set of stock BANSHEE rear hubs and rims. Then you can put the hubs on the blaster and you will have the 115 bolt pattern and 9'' rims.
Old Aug 25, 2004 | 02:39 PM
DRoCk's Avatar
I just ordered the stuff to convert the hubs. Now i just need to decide on tires and wheels. I am thinking of going with a set of ITP wheels and tires, but don't know what size tire to go with. I don't like the tall tires and don't really ride anywhere that needs a lot of ground clearance.
Old Aug 25, 2004 | 02:42 PM
Shav0's Avatar
Stock is 21-10-8,
For MX a good size is 18's, but for everyday riding I would go with 20-11-8 ( or 9'' rims if thats what your getting)
Old Aug 25, 2004 | 02:55 PM
DRoCk's Avatar
I think i am pretty set on a set of 20-11-9s. At least then i will have a couple different sizes to choose from with the nine inch wheels. By the way Shav0, what kind of swingarm and rear shock do you have? I want one sometime in the next year or so, and am starting to look around for one.
Old Aug 25, 2004 | 03:14 PM
Shav0's Avatar
+4,
The rear shock is stock for now, Im hoping to get some works real soon
Old Aug 26, 2004 | 11:44 AM
DRoCk's Avatar
What about your axle, are you still using the stock one? I don't know how much more width i will need when i have wider tires and spacers on the stock one. I also don't want to get into new front a-arms to widen that out right now.
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
tysonbully
Sep 28, 2015 02:30 AM
r1pilot83
Sep 27, 2015 07:38 PM
