Ignition relocation for Lakota/Mojave
Old Aug 26, 2004 | 08:11 PM
LakotaTim's Avatar
Default Ignition relocation for Lakota/Mojave
Where is the best place to relocate the ignition after putting on a smoothy hood?
Old Aug 26, 2004 | 09:17 PM
clover's Avatar
I relocated mine on the bottom right side plastic and tie strapped the ignition wire to the frame,to keep it from the exhaust.It worked out good and looked pretty good.
Old Aug 26, 2004 | 09:37 PM
Illus's Avatar
I just relocated mine the other day. I have an 01 Lakota Sport, and I moved it straight down. If you look on the right side of your Lakota, right where the word KAWASAKI ends on the sticker, there is a spot there. I used a Uni-bit and drilled a hole, and filed a slot for the tab, worked just fine, looks like it was supposed to be there.
Old Aug 26, 2004 | 10:34 PM
rolsmojave3's Avatar
both sound good or put it and the reverse light together on the side panels
that'd look cool
Old Aug 26, 2004 | 11:29 PM
LakotaTim's Avatar
Thanks all
Old Aug 27, 2004 | 01:26 AM
96lapiscoupe's Avatar
I unplugged mine and threw it in the garbage can.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Aug 28, 2004 | 12:09 AM
Illus's Avatar
Hey LakotaTim, did you get it moved? Where did you put it? If you want a pic, I can E mail you a pic of where I put mine.
Old Sep 2, 2004 | 02:47 AM
BigChris's Avatar
Hey All,
I moved mine to the Handle bar dash, just got some washers, and screwed it into the plastic part of the dash, so it looks like most of the newer sport quads key location,
works good, looks good
~CHRIS~
ultangler
Nov 30, 2024 01:35 AM
EIF
Apr 20, 2017 07:15 PM
kbazzy
Sep 26, 2015 11:26 AM
Sw00p
Sep 24, 2015 02:50 PM
