Sand in motor
Old Aug 30, 2004 | 08:25 PM
ClutchOlds's Avatar
Default Sand in motor
My buddies Raptor got sand in the motor. The carbs went and started pouring fuel out of the carbs. We switched over another set of good carbs and the bike won't start. It sounds free spinning. The compression is around 120-130psi and the timing is on. It also has spark. Any ideas of what to check or what could happen. Thanks.
Old Aug 30, 2004 | 09:12 PM
yamrpt660r's Avatar
uhh depending on how long that sand was in there...may just want to tear apart the entire motor and clean it all out and check EVERYTHING bad bearings arent something to ignore
i would atleast tear apart the head and check the valves, if everything checks out it sounds like its probally something stupid that needs attention
Old Aug 30, 2004 | 09:32 PM
RaptorOwner's Avatar
Did you pull the spark plug and see if it was actually turning? Could be the timing chain or one way bearing.... Just a thought bro.
Old Sep 1, 2004 | 10:57 AM
maddog56's Avatar
That compression sounds way too low. I think its supposed to be at least in the 180 range on a stock setup.
Old Sep 1, 2004 | 11:19 AM
moldycheese's Avatar
ya. i think the motor is blown
Old Sep 1, 2004 | 11:46 AM
Shav0's Avatar
How did he get sand in the motor? How much got in?
Old Sep 1, 2004 | 02:21 PM
garyc660R's Avatar
149 is the low end compression limit as per the manual. I would make sure the battery is charged and the throttle was wide open for the test.
Gary
Old Sep 1, 2004 | 05:48 PM
ClutchOlds's Avatar
Foam filter let sand through. Will check again with a battery charger on. Will do in couple hours.
EIF
Apr 20, 2017 07:15 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Clint Russell
Sep 25, 2015 03:20 PM
BYC
Sep 25, 2015 02:10 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
