Sand in motor
My buddies Raptor got sand in the motor. The carbs went and started pouring fuel out of the carbs. We switched over another set of good carbs and the bike won't start. It sounds free spinning. The compression is around 120-130psi and the timing is on. It also has spark. Any ideas of what to check or what could happen. Thanks.
uhh depending on how long that sand was in there...may just want to tear apart the entire motor and clean it all out and check EVERYTHING bad bearings arent something to ignore
i would atleast tear apart the head and check the valves, if everything checks out it sounds like its probally something stupid that needs attention
149 is the low end compression limit as per the manual. I would make sure the battery is charged and the throttle was wide open for the test.
Gary
Gary
BYC
Sep 25, 2015 02:10 PM
