Winch power switch
Old Sep 5, 2004 | 08:48 PM
tyler711's Avatar
Default Winch power switch
Got a superwinch atv3000, but i always hit the "roggle" switch on the bars when i'm riding. Its starting to chew up my fairlead and the loop at the end of the cable. I noticed my neighbor's dealer puts a nice switch on the pod to turn the power off. Which wire should i switch to do this? I had the winch installed, and there are lots of wires lol Thanks, tyler.
Old Sep 5, 2004 | 09:12 PM
SPORTSMAN70003's Avatar
you should have a small red wire that is coming from your solenoid that goes to your switch. You can take and cut the wire and put a switch in between it so you can turn it off and on.
2003 POLARIS SPORTSMAN 700 TWIN
MODIFCATIONS
1.SUPER DUTY HIGHLIFTER CLUTCH
2.AAEN EXHAUST
3.27'' GBC GATORS
4.DYNOJET KIT
5.REVERSE LIGHT
6.CUSTOM NERFBARS
7.FRONT BRUSHGAURD
8.REAR TUBE BUMPER
9.2500 LB RAMSEY WINCH
10.POLARIS HANDGAURDS
11.GEL GRIPS
12.FUEL GAUGE
13.K&N AIR FILTER
14.3'' WHEEL SPACERS
15.HEADLIGHT MODIFCATION
16.REVERSE OVERRIDE MODIFCATION
17.COIL SPACERS
18. 1'' SPRING SPACERS
Old Sep 6, 2004 | 12:20 AM
tyler711's Avatar
ok thanks. how many amps should the switch be rated for? and i had a dealer install my winch, but the solenoid is upside down. superwinch said that should be dealt with asap, but we havent gotten around to it yet. why is it so important to have it right side up? TIA TYLER
Old Sep 6, 2004 | 09:54 AM
20045SP500HO's Avatar
yes the solenoid must be right side up. It will fail fast upside down.
toonces
Oct 19, 2015 02:21 AM
user493
Aug 13, 2015 12:54 PM
Gtsordo
Jul 22, 2015 01:27 PM
toonces
Jul 11, 2015 12:01 PM
cornermike
Jul 8, 2015 11:44 PM
