Hello every one Im new hear I just got my 450R today
Old Sep 5, 2004 | 11:00 PM
Rcpilot's Avatar
Default Hello every one Im new hear I just got my 450R today
I had pland to buy one this fall when it gets a little cooler but My dealer had them for 5675.00 + tax I could not turn that down so I got one is ther anything I NEED TO Know I have been reading this forum for a whyle and have read some of the issues with the 450R I want to put a pipe on it witch one would be best I dont want to loud of one. also I have not got the HRC kit yet dealer was out of stock also what nerffbars do you recomend
Thanks Tim
Old Sep 6, 2004 | 11:32 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
I highly recommend this method for break-in. http://www.mototuneusa.com/break_in_secrets.htm Actually, they ran your 450 on the dyno at the factory, so they already started the process for you!
I change my oil and filter after 1-2 hrs. to get rid of all the metal shavings, then again at 10 hrs. Use Honda GN4 (dino) oil for the brake-in period (~10 hrs.). Read this great article about oils. Everything that applies to the CRF's, also applies to your 450. http://www.thumperfaq.com/oil.htm
Your 450 is unique because you can run different oil in the transmission and engine. After break-in, I prefer to run Honda HP4M (a slick JASO MB oil with moly) in the engine, and Honda HP Trans Oil in the transmission. Watch your oil carefully, and change it often!
Do a valve adjustment at about 20 hrs., too. Do get the HRC kit, when you can. I run DG Race Peg nerfs, and highly recommend them!
Old Sep 6, 2004 | 11:58 PM
Rcpilot's Avatar
Originally posted by: reconranger
I highly recommend this method for break-in. <a href="http://www.mototuneusa.com/break_in_secrets.htm">http://www.mototuneusa.com/break_in_....htm</A> Actually, they ran your 450 on the dyno at the factory, so they already started the process for you!
I change my oil and filter after 1-2 hrs. to get rid of all the metal shavings, then again at 10 hrs. Use Honda GN4 (dino) oil for the brake-in period (~10 hrs.). Read this great article about oils. Everything that applies to the CRF's, also applies to your 450. <a href="http://www.thumperfaq.com/oil.htm">http://www.thumperfaq.com/oil.htm</A>
Ok Thanks for the info
Old Sep 11, 2004 | 02:48 AM
450r's Avatar
even though i bought the kit i would not recomend it. unless of course thats all you plan to do. if you plan to do a pipe then forget the hrc kit. just buy an after market cam. most pipes come with jets but if they don't, a jet kit is cheap enough.
hrc kit=$200-300
slip-on=$250-400
jet kit=$25-50
cam=$125
hrc kit,pipe=$450-700
slip-on,jet kit,cam=$400-450
i liked what the kit did ,but i like what i am running now even more.it may be a little to loud for some, but there are other pipes out there.like i said before ,i liked what the kit did ,just consider your options. don't buy the kit just because it's there or they can get it.
Old Sep 11, 2004 | 04:00 AM
Rcpilot's Avatar
Ok thanks
so if I just do the HRC kit would you recomend just a slip on just for the sound I don't plan to do more than just the kit I not going to be racing it mostly trail riding
Thanks Tim
Old Sep 12, 2004 | 01:18 PM
450r's Avatar
yes the kit will do just fine for you ten, but i recomend a 13t front sprocket for the trails. it takes less clutching do to the tall gears in the tranny.
Old Sep 12, 2004 | 03:31 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
Welcome Tim!!
Nice bike,,,ride safe,,,enjoy the forums,,,,and get some pics on your bio page!!
Dewhound
Apr 20, 2017 02:25 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
Clint Russell
Sep 25, 2015 03:20 PM
cboler9
Sep 24, 2015 08:35 PM
