AC 4wd shift on the fly questions.
Old Sep 7, 2004 | 03:01 PM
ethernut's Avatar
Default AC 4wd shift on the fly questions.
For you guys with experience on the new AC bikes (2004 and 2005), can you shift from 2wd to 4wd (limited slip) on the fly with the thumbswitch on the 500's and 650's? What about locked, do you have to stop to lock the front diff or can you nudge it in if you get in trouble?
Old Sep 7, 2004 | 09:40 PM
heyyou's Avatar
I think its a lot like the yamaha shift on the fly,I shifted it whenever,where ever.As for the diff lock question,don't know for sure,asked that question myself on ArcticChat,without much luck.
Old Sep 9, 2004 | 01:00 AM
vrz500tbx's Avatar
if you aren't spinning you can shift on the fly...
if your tires are spinning you cannot....it will be tough on the gears
pretty simple.....same as anything that is 4 wheel drive
Old Sep 10, 2004 | 11:32 PM
westpamudder's Avatar
I am not positive, but pretty sure you shouldn't lock in the front diff with the tires spinning. Could probably do more damage than good. As for shifting into 4wd when moving, that shouldn't hurt anything, as long as you have traction at the rear wheels.
Old Sep 11, 2004 | 12:02 AM
heyyou's Avatar
If it will hurt the front diff then it must be different than the prairie,they can yard it on whenever they want to.
95wolv
Sep 27, 2024 12:00 PM
mark23
Oct 1, 2015 09:57 AM
Clint Russell
Sep 25, 2015 03:20 PM
bigred20653
Sep 19, 2015 02:11 PM
BigCam
Sep 16, 2015 01:53 AM
