Scrammy starter problems
On my 2000 Polaris Scrambler 400 The electric starter use to not work when I first tried to start it up but worked fine after it had already been pull started and running. It clicks when you push the start button.
Now it don’t work at all, even after it has been running, just clicks. What could be the problem here, the connections, the solenoid? The battery seams to be fine, I checked the connections here and topped it off with distilled water and charged it with my Battery Tender Jr..
Make sure the battery is good(battery charge checker), check all connections from the starter back through the solenoid, to the battery.....and if the battery is good, then its probably the solenoid. I think, but not sure, that you can check the solenoid by turning the quad key on, and seeing if there is power to the battery side, and then hit the start button, to see if power goes through it.
It really sounds to me like a loose connection, or your battery doesn't have enough power to turn the quad over, so your starter is kicking out.
The same kind of problem can happen when the brushes are just about dead.
I had that problem, replaced the battery and it didn't help.
tore out the starter and the brushes were shot. replaced them and all was well again.
-Chris
-Chris
Originally posted by: hawleywood
mine is doing the same...can you jump the solenoid like cars to check it??
