New WARN winch will not free spool?
Old Sep 10, 2004 | 06:28 PM
20045SP500HO's Avatar
Default New WARN winch will not free spool?
I got my new Polaris Sportsman 500HO with the Polaris WARN winch kit ... i can't get it to free spool. Any ideas.
Old Sep 11, 2004 | 09:49 AM
Krank's Avatar
Have you used it at all yet. If not there is only one idea that I can think of...
Old Sep 11, 2004 | 11:46 AM
yaK's Avatar
yaK
is there tension on it as you are trying to move it? can you move the lever...need more details to get an idea
Old Sep 11, 2004 | 06:47 PM
You can put the **** in the free spool position ... but its really hard to get it there and you can free spool the drum but man you REALLY pull HARD to get the cable out... my old WARN is easy it free spool, if you pull hard the cable will spin the drum.
Old Sep 12, 2004 | 01:49 PM
yaK's Avatar
yaK
are both of your's the same? mine u got to pull fairly hard....also wouldnt want it to just loose all tension as with 50 ' of cable all floppy in there.... I am considering cuting teh cable down to 15 feet anyway and just using webbing for anything longer as its a pain in the *** to wind all that wire up anyway.
Old Sep 12, 2004 | 03:53 PM
Both winches are the same model ... one is off my old sportsman and is 8 months old, it works great and free spools easy enough for a 2yr old to pull out the cable. The new one, i have to put all my 190lbs into it to just get a few feet out of it with each pull.
Jeff Roper
Feb 1, 2022 11:48 AM
Johnny Mac
Aug 15, 2019 03:13 PM
panicmanic
Sep 28, 2015 12:59 PM
2many2ride
Sep 27, 2015 04:35 AM
cboler9
Sep 24, 2015 08:35 PM
