Front hub on sportsman 500 HO
Old Sep 11, 2004 | 05:18 PM
Zbart1's Avatar
Default Front hub on sportsman 500 HO
I put my bike up on the stand and started and engaged allwheel drive. Only one wheel in front turned (drivers left) both drive shafts turn, so i'm thinking the electric clutch is to blame.
I'm new to this set up so i'm looking for some input as to trouble shoot this set up. .......what is prone to break?
I did check the fluid ........seems fine
Thanks
Old Sep 11, 2004 | 08:37 PM
rmkcac700's Avatar
most likely a broken wire to the hub coil.un plug it under the front hood, and put a multimeter on it. brown wire to grey wire 28 ohms. if open , broken wire, if higher reading, shot coil.
Old Sep 12, 2004 | 10:51 AM
Zbart1's Avatar
Thanks for the info MK ..........will check that first.
Jmuddin284
Jan 19, 2026 07:16 AM
traumajunkie
Jul 5, 2015 03:03 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
Mphillips
Jul 2, 2015 07:20 PM
