Buying an ATV Questions and suggestions about what to buy, financing, insurance, etc.
Routine Maintenance / Normal Wear & Tear ?
Old Sep 13, 2004 | 07:17 PM
phunzoid's Avatar
Default Routine Maintenance / Normal Wear & Tear ?
what sort of routine maintenance would a 0-3 year old 4-stroke ATV require? (ie. Honda 300EX or 400EX)...how much does it generally cost?
assuming no bad crashes or extra-hard use, what parts tend to wear down the fastest, requiring replacement (ie. clutch, chain, etc. ??)
anything to specifically watch out for when buying a used ATV?
Old Sep 13, 2004 | 07:49 PM
Jibrille's Avatar
4 stroke sport quads I'd assume normal stuff.
Chain, sprockets will wear the fastest I think. Check sparkplugs, bearring carrier (where the swing-arm holds the axel), actually any bearings period.
I think those are the vitals to check for. If you dig inside of it, check valve clearence, filter, carb,,, stuff like that.
Old Sep 13, 2004 | 11:12 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Either of those Hondas will probably run forever, without any major problems. Routine maintenence: Clean air filter, change oil and filter, spark plug, valve adjustments. Tires, and occasionally a chain and sprockets. Anybody who can afford a bike, can easily afford to maintain it.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
dannytas
Sep 26, 2017 06:31 PM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
cboler9
Sep 24, 2015 08:35 PM
