ok all you tecnition's figure this one out?
yesterday went for a ride on my p700 ,shut machine, off wouldn't start, so used pull starter, fired up get home check it out, puting out 15 to 16 volts at idle, stab throtle and drops to 3 to 4 volts. i'm thinking voltage regulator or stator never messed with elec. stuff before so this is all greek, pulled fuses while running, no deferance any ideas would be awsome thanks .Vern.
do you have a service manual? I don't have mine here at home and I can't remember but I belive they have a test in there you can do to check the regulator/rectifier. Looks like it is over charging then not charging,,,, check to make sure all connections are good,,, seen a stick unplug the regulator before. It actually broke the connector. Location is under right rear fender.
thanks guys , simple fix wire was broken on voltage regulator causeing it to dump 17 volts in to battery,battery had all she could take of that and gave up the ghost new battery installed wire fixed 14 volts to battery alls good
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
