4wd Problem
Old Sep 14, 2004 | 10:17 PM
500HOSportsmanRSE's Avatar
Default 4wd Problem
Hey there! I'm having some trouble with the 4wd system on my 2002 Sportsman 500HO. When I'm in 4wd the right front tire doesn't do anything. It makes a clicking noise when I push the machine in neutral with it shut off. I jacked it up and ran it in 2wd and the right front tire spun slowly while the left one stayed still like it should have. When I put the machine in 4wd the left front worked fine but then the right front stood still like it does when I'm out in the woods. Is the right front maybe in between being engaged and disengaged? Could it be in the 4wd button? Or do I have some broken parts inside? I do not recall ever putting it in 4wd with the rear tires spinning. I read the warning label. But, maybe it slipped my mind once. Any help would be appreciated. Thanks.
Old Sep 14, 2004 | 10:56 PM
ftwflh's Avatar
Default 4wd Problem
Check the hub fluid before you panic.
Old Sep 18, 2004 | 12:43 AM
PhilFixit's Avatar
Default 4wd Problem
The electric wires that go to the Polaris front hubs are notoriously fragile. You may have a broken wire.
BTW, the oil that goes in the hubs isn't anything special, it's the same oil that goes in your Polaris 4 stroke motor. (0W-40 synthetic motor oil).
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
