vdi snorkle mod for 650
Old Sep 17, 2004 | 09:05 AM
ReserveCat's Avatar
Default vdi snorkle mod for 650
Has anybody done a vdi snorkle mod to the airbox of a 650 cat. i searched the forum and could not find any posting in the last few months. My question is this - What jets do you use for the carbs. I read somewhere that #138 jets should be used. I have them ordered but they are on back order for a month at least. I have ordered #135 jets hoping they will work just as well. Not really mechanically inclined. My friend does all the work. Any opinions would be appreciated.
Old Sep 17, 2004 | 10:49 PM
heyyou's Avatar
I asked this question in the kawi forum and KOD said go up one size from stock.If you go to ArcticChat.com there is a lot of info on this mod.
Welcome to the site,good to see a fello Bluenoser.
Old Sep 17, 2004 | 11:53 PM
DaveB's Avatar
Stock for the Kawi is 138 front, 142 rear......stock for the AC is 128 in both. I went to Kawi stock sizes after opening up the airbox intake (VDI mod).
Old Sep 18, 2004 | 12:55 AM
heyyou's Avatar
My manual says 122 front and rear.
Old Sep 18, 2004 | 01:27 AM
weez440's Avatar
whatever you guys find out would be appreciated by me and alot of people cause i been thinking of a snorkle kit you can't help but lose power but if i can run almost underwater it is worth it and do you have to drill a hole in your front fender????? this is a whole new area that i think i need to explore for myself
Old Sep 18, 2004 | 02:25 AM
DaveB's Avatar
Heyyou.....you are correct.....I was just going from memory, which is not great!
Old Sep 18, 2004 | 06:57 AM
heyyou's Avatar
You can put a larger snorkle on and stay at stock height,thats what I plan on doing,don't want to cut any holes.
Is that what you did DaveB?Is it a custom job?
Old Sep 18, 2004 | 07:59 AM
DaveB's Avatar
I put a 2-1/2" 90 deg elbow directly into the airbox by drilling over the stock "stub" sticking out of the airbox with a 2-3/4 hole saw. I then drilled a hole in the plastic and ran it to the outside.
mich660griz
Feb 10, 2002 11:42 AM
sly
Apr 10, 2001 09:26 PM
tomrobalo
Mar 30, 2001 11:17 PM
