Raptor Steering Stem Bearing Removal
Old Sep 19, 2004 | 06:19 PM
RaptorOwner's Avatar
Default Raptor Steering Stem Bearing Removal
Any clues on removing the large hex looking nut at the bottom of the steering stem that holds the bearing in the frame? Is it reverse threads?
Old Sep 19, 2004 | 06:27 PM
wshrdskin's Avatar
That nut is suppose to be at 80 ft lbs and it's normal thread. Turn it a little harder. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 19, 2004 | 06:30 PM
LOL!! I fell like I am going to bend the frame!! I couldnt find a damn thing to use on that so I grinded down an old hammer to make it fit in there and it works great but no leverage, either going to bend the frame or break the hammer!! [img]i/expressions/face-icon-small-shocked.gif[/img]
Old Sep 20, 2004 | 01:54 AM
sandjunky660's Avatar
put some heat to it. u have to break the lock tite.
Old Sep 20, 2004 | 02:16 AM
XR650Warrior's Avatar
you can tap it out with a chisel but then will need a new nut on re-install, no heat needed.
We've made our own tool now, get you a bolt from the local hardware with a head that fits in the nut, weld a nut on the other end and put a 1/2 drive ratchet on it and it is easily installed or removed.
Old Sep 20, 2004 | 09:42 AM
UBETRUN's Avatar
I removed mine with a hammer and a flat blade screwdriver. Just put the screwdriver into the corner of the hex nut and tap it until it turns a little. Keep moving the screwdriver to the next corner of the hex nut and work that sucker out of there. I didn't beat up the nut too bad, it could be re-used.
Old Sep 20, 2004 | 10:54 AM
Thanks,
I will try the new options suggested and hopefully this will get it out.
Old Sep 20, 2004 | 11:03 AM
sixsixT's Avatar
I had a big bolt that fit it almost perfect and used some visegrips on the bolt.
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
1966F100
Jul 12, 2015 03:01 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
