03 Sportsman 500 HO
Old Sep 20, 2004 | 01:55 PM
Cryokid's Avatar
Default 03 Sportsman 500 HO
Good day to all.
My friend has a 2003 Sportsman 500 and he has the following problem:
It is hard to put in gear, your can hear the gear grinding, also, when it is in gear,
it will start moving at idle.[img]i/expressions/face-icon-small-confused.gif[/img] Now does he need to adjust the linkage or
is it clutch trouble????
Thanks for your help.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 20, 2004 | 03:18 PM
Cryokid's Avatar
Any one???[img]i/expressions/face-icon-small-blush.gif[/img]
Old Sep 20, 2004 | 04:42 PM
ibdboss's Avatar
The problem is with your clutch. It isn't fully disengaging thus making it hard to put the bike into gear. If I am not mistaken I think that the primary needs to be shimmed out a little to make the belt line up in the middle. This is a simple fix and should be nothing to worry about. It should only take a dealer about 1/2 hour to fix, and maybe an hour for you.
Old Sep 20, 2004 | 08:29 PM
Cryokid's Avatar
Thank you ibdboss
I will check this out with him
and keep you posted
Tks again.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Sep 20, 2004 | 10:30 PM
NBsportsman's Avatar
Sounds like the idle is set to high. Should idle at 1200rpm(don't know if there is a tac on the 03).......
Old Sep 20, 2004 | 10:58 PM
yaK's Avatar
yaK
i agree with the idle diagnosis...adjust that first..then go from there...
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
