Whats Speed shifting?
Old Sep 21, 2004 | 12:23 AM
Warriordude14's Avatar
Default Whats Speed shifting?
I've heard several guys talk about how they speed shift and i have no idea what it is. Is it bad for your quad or just not using the clutch. Just help me out.
Old Sep 21, 2004 | 12:25 AM
pimp250r's Avatar
It's basically where you don't let off the gas when you clutch...and you clutch mighty fast. You will gain time by doing it if you do it correctly.
clover's Avatar
speed shifting is shifting without using the clutch lever and yes its bad in the long run for your transmission.
Old Sep 21, 2004 | 02:24 AM
Starky's Avatar
Never speed or power shift with a 2-stroke. You shouldn't do it with a 4-stroke but you can. When you let off on the throttle there is a slight pause before the compression takes over. It's during that pause when you shift without using the clutch. If you do it wrong you will know it because your gears will slam together. Also, if your going to do it, only do it when you are up-shifting.
Old Sep 21, 2004 | 02:51 AM
ItalianStallion's Avatar
Clutch...whats that..[img]i/expressions/face-icon-small-wink.gif[/img]
Old Sep 21, 2004 | 02:58 AM
Sandfox24's Avatar
I speed shift all the time. Been doing it for years on every 2-stroke I have ever had. I slightly let off the throttle while slightly pulling in the clutch and shifting. IMO, done correctly it wears the clutch more than the tranny.
Old Sep 21, 2004 | 06:48 AM
Jibrille's Avatar
I totally agree. I only ever really do it dragging, or Wheelie shifting.
Old Sep 21, 2004 | 02:52 PM
RoostItUp's Avatar
If you're gonna speed shift get an override tranny, it makes it where 3rd through 5th gear are shaved and all it takes is a slight tap on the shifter to get it into gear. Very good for those draggin Shees out there that don't wanna use the clutch and don't wanna lose speed shifting.
Pehter
Oct 3, 2024 11:00 PM
95wolv
Sep 27, 2024 12:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
ReconBayou
Sep 23, 2015 02:41 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
