Honda problems!
Old Sep 23, 2004 | 11:26 PM
riderman's Avatar
Default Honda problems!
Had the quad for 2 days now and some problems are starting to show up. One, I took the drum off to look at the rear brakes, and they looked good and fairly clean with some brake dust. Well I adjusted them to were they was tight and rode it. After applying the brakes they stick, and wont let go until you go a couple of feet, so I had to loosen them up. The second problem seems to be a little more severe. The boot that covers the u joint in the rear shaft, just as it is leaving the engine, has a cut in it. Oil is leaking through this cut, and it only leaks when the quad is running. It is not a fast leak, but a slow drip. I believe the problem to be a leaking gasket. What do you guys think? Also, I do not want to have to do anything to it till the end of deer season. I just don’t have the time, and I like to do all my maintenance work myself. So, will it wait four months till the end of the season? I don’t think that water will be able to get in, because of the higher oil pressure in the engine. Overall the quad is in good condition, other than the above and the valves needing adjusting I am happy with it. Thanks for the help.
Old Sep 24, 2004 | 12:43 AM
LittleBill's Avatar
i would not let it go, the tranny and the engine use the same oil, either replace the boot, or ductape or electric tape the crap out of it and keep it out of water
Old Sep 24, 2004 | 10:14 AM
riderman's Avatar
Old Sep 24, 2004 | 10:03 PM
mudblaster's Avatar
what kind of honda is it.
you dident say.
Old Sep 25, 2004 | 12:33 AM
riderman's Avatar
Rancher
Old Sep 25, 2004 | 10:07 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
You said the boot "has a cut in it" but you believe it is a "leaking gasget"??? What does a gasget have to do with it??? It's just leaking grease out of the cut!
Old Sep 25, 2004 | 02:49 PM
riderman's Avatar
It is not grease leaking, it is oil. Should the saft there have oil in it like the rest of the quad? I believe it is leaking out of the trans, were the shaft leaves the engine, and it is flowing out the boot were the cut is at.
Old Sep 26, 2004 | 01:05 AM
hondabuster's Avatar
What year is that rancher? Should be a seal, in the crankcase, where the shaft comes out. And you should replace it and the rubber boot. If oil is coming out, i means it isnt going to keep stuff out either. You could wait to fix it, but try to not let water or dust and dirt in. A temporary fix, would be to seal up the cut, to keep stuff out, until you have time to put in a new seal.
Old Sep 27, 2004 | 12:24 AM
riderman's Avatar
2001, Thats sounds about right hondabuster. Does anybody have a engine diagram they can send me. My email is evan5o2@hotmail.com
Old Sep 27, 2004 | 10:28 PM
riderman's Avatar
does everybody agree with hondabuster?
Sjrpp
May 2, 2023 03:59 PM
hugemoth
Jul 20, 2020 03:28 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
